I have a buddy that wanted to switch his rims around on his 4 stroke. He took the tires off and removed the valve stem then put the valve stem back on inside out. Looked like he just plugged the hole. He then drilled the other side of the rim and pulled a valve stem thru that side. It sounds like alot of work but he is a tight ass.
