I hope ur not putting in 180, the jet that comes in the kit is a 280, and your airscrew should be around 1 1/2 turns out and clip on 4th groove i believe. You might have to adjust your idle. asnd right there is ur problem your using their needles dont they suck, just use the stock ones they work better i was told this same thing when i got my T5 kit for my 05. I tried them once and they are still out bc they dont work right.
Edited by BlueBanshee05
I am guessing you bought the jet kit, make sure you drill the holes out for the little vents....
I had to take the snorkel off also. Did you do all of this. When I installed my t5s I didnt have to adjust any air screws.
