AustinONeal Posted October 23, 2006 Report Posted October 23, 2006 I was at little sahara this past weekend and i raced a guy that has pretty much the same mods as i did all stock with a butt load of bolt on's and ported , 165 lbs per cylinder and he said he was has been runing 87 octain gas forever and never anyproblems, and i have been running 111 forever and my question is what shouldi be running. Quote
dajogejr Posted October 23, 2006 Report Posted October 23, 2006 I was at little sahara this past weekend and i raced a guy that has pretty much the same mods as i did all stock with a butt load of bolt on's and ported , 165 lbs per cylinder and he said he was has been runing 87 octain gas forever and never anyproblems, and i have been running 111 forever and my question is what shouldi be running. One of two things. either his compression tester is broken, or....his shit is ready to blow up. Quote
warwgn Posted October 23, 2006 Report Posted October 23, 2006 very simple answer................run the lowest octane you can without overheating or pinging. Quote
AustinONeal Posted October 23, 2006 Author Report Posted October 23, 2006 very simple answer................run the lowest octane you can without overheating or pinging. ill keep running 111 it is running great i dunno if its gettin hott though but when the weather cool down to about 60 it runs even better than it did before is that a sign that the gas is too hott>? Quote
dajogejr Posted October 23, 2006 Report Posted October 23, 2006 It's not getting too hot from 111 octane. One of two things, if not both.... Any engine runs better in cooler temps...cooler engine, better running. And..or... You might be a little rich, with a little cooler temps, it leans your jetting ...so, one or both. Quote
