alisn4x4 Posted October 22, 2006 Report Posted October 22, 2006 so i finally split the cases and found the ailment to the motors problems. apperently it ate a rod bearing. so this is where im at.... ive got the whole bike torn down and the rod bearing being chewed up is seemingly gonna cost me some. so what are my options as to what i can do? should i send it out to have the crank redone? should i find and buy a good used one that someone has swapped out for a stroker or what can i do?? i dont have deep pockets to begin with (who does?) and im afraid this is gonna suck up alot of cash depending wich route i go so...... any opinions?? thanks. Quote
Bansh-eman Posted October 22, 2006 Report Posted October 22, 2006 if your not looking at going stroker or anything pecial then find someone with a good stock crank... you can find them a dime a dozen... while your at it replace your pistons and you should be good... check your cylinders and see if they need to be honed... Quote
alisn4x4 Posted October 22, 2006 Author Report Posted October 22, 2006 thanks, thats what im looking into is someone's good stock crank w/rods and hope to find one i can drop in and go. im gonna order some wiseco pro-lite's and have the cylinders bored/honed and matched to them. im having the cases cleaned monday of any debri inside there. kind of disappointing to find that messed up.... was hoping to just be able to order parts monday and have the motor back together by the time the frame came back from PC. Quote
