I have a 97 banshee with toomey t5s, airbox eliminator, reeds, and jets. Im going to put a head on it that is milled and shaved just enough to run pump gas. Do I have to change my jetting? If I do, what jetting should I use?
Most of the time, running pump gas with milled head, supposed not smaller than 20cc and 21cc at sea level you get away with no jetting changes, but do n plug chop. If at sea level go 2 sizes up and work from ther, but i bet youll get away with it.
Good luck
