Sounds to me like you are grabbing the address of the link to your image, as opposed to the address of the image file itself.
The address you want to put between the brackets should look something like this: http://www.bansheehq.com/adserve/adimage.p...nossmachine.jpg
where the address ends in .jpg instead of .html. Make sense?
Copy the 'Image Location' not the 'Link Location' :wink:
Edited by 350TwinDeathBed
If you're using firefox: Right click the image itself & click "Copy Image Location"
If you're using IE: Right click the image & click "Properties". highlight the address/url (right click it & 'select all'). right click & "copy". Be sure to click OK and not cancel. Mickeysoft's copy won't work in IE if you click cancel...doesn't make sense i know, but trust me on this.
There you have it, a direct link to the image...well, it should be the direct link. I like the 1-step approach in Firefox. If you're not using it by now, it may be a good time to switch.
