hi every one i'm new and i got a problem.
i just installed new pipes and re jetted and changed the needles on my bahsee and now that ive got every thing back together it's not starting. I checked the plugs to see if their sparking and they are but it doesn't seem like thiers ne gass getting to them like thier not wet at all could this be the needles or what??
thanks for the help
yea that black tube that come from the gass tank. and sperates ino the carbs right
The tube that run sform on side of the carb to the other.Take the fuel line off the tank and see if you can blow thourgh it prferably one carb at the time if you cant then the float is proably stuck or out of adjustment.
how would you adjust your float?? and where is it located?
Well you need to find out if thats th problem first. Its located on the bottom of the carb in the bowl its that big black thing that swings up and down if you didnt bend anything it should still be in adjustment you adjust it by bending the little tab that has thelittle valve hanging on it but it doesent take much to over do it. If you go to far it will flood the bowls and fuel will come out the ovwer flow to much the other way and no fuel will enter the bowl. Take them off and turn them up side down and see if that will reset them.Oh yea go first thing and pick up a climers.
Edited by RILS
yea i got a climers i bet thats the problem their... atleast i hope thats the problem
If your not getting fuel I almost guarentee the problem is there.
