Eddie Posted September 30, 2006 Report Posted September 30, 2006 is it safe to completely remove the throttle restrictor Quote
Banshee4Drag Posted September 30, 2006 Report Posted September 30, 2006 I dont see why not. the TORS? If you have not removed it, you better. they just cause problem's anyways. Get a kill switch if your worried about it... Quote
dajogejr Posted October 1, 2006 Report Posted October 1, 2006 are you talking about the TORS or the ajustment bolt on the thumb throttle itself? Yes to both....anyways. If you mean the bolt on the throttle house, I'd remove it and get a short bolt to put back in so you don't get dirt/debris in there. The TORS are a great idea in theory...unfortunately, they're bulky and seldom work as they're designed to. Unplugging them is just about mandatory, and removing them with the kit makes things much nicer/easier to work on.... Quote
