Ok, so I pretty much was ready to go away this weekend up until a few minutes ago. Soething just doesnt seem right on my bike. From the back, the right exhaust has wayy more smoke then the left one. As a matter of fact, there is no visible smoke coming from the left side throughout the RPMs. And the right side basicaly had oil dripping out after only a few minutes. I had the carbs apart last week, and this is the first time I started it since. Both have 260 mains, 25 pilots, air screws 1.25 turns out, and the idle is set perfect. This setup worked perfct for me for a long time, at sea level and 60* temps. I also cleaned both last time I took it apart. The mods are in my sig under the 2002 banshee. I do not know what I did, if one carb has some carb cleaner left that's burning off, or if I put too much oil on my filter and it only got through 1 carb. Anyway, any help would be greatly appreciated. I'm leaving at 6pm today for Pennsy. Thanks!
All right, I'm really at a fuckin' loss! Jet needles are on the 3rd clip up, both are the same, plug chos looks on spot on the right cylinder, and "decent" on the left. I guess it must be an air leak? The bike starts with one easy kick, I can pretty much start it with my hand that's how easy it is. I'm lost, any infow ould be greatly appreciated. There is a pretty decent smoke difference too.
