hello,
i bought a new clutch hand lever and cant get the cable off the original lever. seems like theres a hockey puck shaped piece of metal at the end on the line that needs to be removed. are there any tipe of c clips holding it from coming off?
i have to get this stupid lever off and the new one on so i can go riding this weekend. any help is appreciated.
thanks
you losen the cable up and there is a slot on the bottom of the lever pull the cable tawards the end of the handle bar. then pull down on the cable and it should come out.
I think he means the levers bent. I have two banshee cables just like that, the damn things wont come out. The levers seem to bend just right so you cant get the cable out. I just take a dremel with a cutting disk and cut the lever. The stock ones arent worth shit anyways.
couldnt get it off so i cut the lever at the insertion point of the cable. needless to say it fell right out. fit in the new lever and now im ready to go. thanks IROOST1
