Bansheeman1121 Posted September 16, 2006 Report Posted September 16, 2006 Ok real quick hooking stock headlikghts up for direct power, got a wire with power but i don t no what to hook it to the black green or yellow , basicly its gonna be quads on headlights on no toggle so what do i hook the power wire to black green or yellow and is there a need for grounds? Quote
gregbowler Posted September 16, 2006 Report Posted September 16, 2006 Black is the ground green is for the low beams yellow is for the high beams Quote
[email protected] Posted September 16, 2006 Report Posted September 16, 2006 green should be ground black is your HOT yellow is your optional hot some way you wire them ones for high beam and ones for low beam Quote
Justintoxicated Posted September 17, 2006 Report Posted September 17, 2006 (edited) black is gound on mine, and lows / highs is easy enough to determin. I believe the above is correct, green low yellow high. Edited September 17, 2006 by Justintoxicated Quote
