Oct 7 at Dumont dunes. I'm trying to get ready if I can get on top of my work load. Should be lots of fun. Whos going from here?
I'm in with three others
What class you guys running in? I'm trying the 350-400 Alky class. Trying to get out Thursday night.
I did not know that there was any classes...........how does it work?.......registration?.....ect.......ect......what day do the races start?............Gimmie gimmie some info!!!!
Not to be an asshole, but the roman numeral for 4 is IV not IIII.
Thanks for that correction :baseball_bat:
You can sign up when you arrive. Here are the classes.
Outlaw Class 2 stoke, 4 stroke (run what you brung and hope you brung enough!)
21mm-26mm
18mm 20mm
16mm
14mm and 12mm
10mm and under BIG MANS CLASS. Rider must weigh 210lbs or over. Bike can be NO bigger than a 10mm, Aftermarket cylinders OK
10mm Aftermarket cylinder 550 cc max
10mm Stock Cylinder
7mm and 8 mm Aftermarket cylinder 550cc max
7mm and 8mm Stock cylinder Aftermarket frame ok
4mm After market cylinder Aftermarket frame ok 500cc max
4mm Stock Aftermarket frame ok
400- 550cc gas only,Stock or stock modified frame only
350- 400 ported and polished alky or gas Stock or stock modified frame only
350 Port and Polish (any Stage) Aftermarket carbs, pipe. Gas only.
350 ported and polished, pipe, stock carbs, stock frame. Gas only.
350 stock carbs, stock frame. gas only. pipe ok. stock or stock modified frame only. (this class is for stock banshees)
4 stroke Stock, pipe only 500- 700cc
4 stroke 500cc and under
21mm-26mm
18mm 20mm
16mm
14mm and 12mm
10mm Stock Cylinder
Banshee Wars I am assuming the 4 stroke classes are for the cross-breed shee's, am I right?
No they are 4 stroke friendly. Bring your Raptor or 450 out and run it.
I just sold my YFZ450, so this will be my first trip out with the Banshee's. Can't wait to see how shee runs! Maybe I'll run the stock calss?!?! Could be fun!
What is the fee?
What is the fee?
They do have a stock gas carb class. Just pipes and filters. I don't know the price but it isn't much.
I will be thert for sure! Im runnin in the 350-400 alky class as well
I'll be running in the same class. Cant wait.
