ok i was riding racing up a hill. Half way up i heard a knocking noise from clutch cover trans area. i shut it off right away. Went home drain trans fluid..Burnt bad.. I removed clutch cover..found the shift star a little piece missing at the end..Wont go into 1st will cylce through all others stops at neutral. Do u guys think that would cause that loud knocking noise or something else smoke in the trans??The star has all the divets in place just a little peice at the end.. Help please
If it won't go into 1st you might have a bent fork. If the shift star actually broke I would split the cases to see what really happened. Shift stars don't break. I've never seen one break. So if yours did something else bad must have happened to cause it to break. I would def. split the cases and check for damage to the forks, glide rods, drum etc.
If you need more help, I have my cases split right now and can get pics of anything you need.
- Jared
