Alright, all this talk about milled heads lately got me askin alot of questions...
What is a milled head? What does the milled mean? What kind of power difference does it make? Can you do it on a stock banshee motor without adding anything?
Any help would be pretty cool,
Thanks
Simply put, you shave material off the gastket surface of your head to raise compression.
From .015 to .030 is common...
It will give you some more snap and bottom end...albeit at the sacrifice (slight) of top end...which, the shee has plenty to lose...
Just make sure you check compression if you do, you don't want to run lower octane gas if your compression gets up there....
