Ok I got the 280 size jets and it acually started "kind of". Well when it started it reved up so i shut it off then i played with my idle and started it again and it still reved. It was also only running on one cylender
Main jets do not effect the starting, unless they fall out....(Don't ask me how I know that one..)
You've either got a stuck throttle cable, a stuck slide, the sildes are in backwards, float bowls switched, choke tube not in place or a real nice air leak....
Start by the most obvious spots. Look for cracking around the rubber boots on the intake side....go from there.
PM machwon for a very reasonably priced leak down kit tester if you can't make heads or tails.
He sells a kit with everything you need that will pressurize the cylinders to check for an air leak...
So I just got took a look at the boots and they have no cracks or holes that I can find. Everything else should be good because all that i did was take the K&N's off put the airbox back on and changed the jets.
