I hear that a set of Yfz 450 front calipers fit bolt on on a banshee spindles it's true?And this is that make a large difference for those which one already try?Sorry for my bad english...
Thanks
Thanks
Just bolt them on bro, I have a set on mine right now, work awsome. I also used the 450 master.
i ahve a question do you have to use the yfz master cylender when useing the break caliper?
I have the yfz450 calipers and master cylinder on mine also. Big improvement over stock. You don't have to use the 450 master cylinder. I am not sure if the 450 master cylinder even makes them work any better.
