I got my first banshee on Saturday. It idles really really high. I checked the evil tors things on top of the carbs and one of them was leaking air. So I fixed that and it still idles high...but not as high. Anyway, I try adjusting the screws on the top of the tors units and it had absolutely no effect. Why won't it adjust? I have gotten a few suggestions from friends, but nothing has been helpful. Does anyone know what is wrong with my banshee? Thanks in advance.
Check the cable adjustment at the thumb throttle. Also spray carb cleaner around the carbs, intakes and cylinders to check for air leaks. If the motor revs up you have a air leak there.
