MYquadsFaster Posted August 29, 2006 Report Posted August 29, 2006 i use yamalube premix oil and i mix it 40-1 and there is oil comming out my pipe pretty heavily.. thats the lowest amount of oil yamalube recomends....is this normal? do you think i should use an even higher ratio like 50-1? let me hear your thoughts...... mods +4 mm stroke .80 over mild port cool head 22cc domes trinity single 35mm carb v-force reeds cpi pipes timing advanced 4 degrees k&n filter Quote
J-Madd Posted August 29, 2006 Report Posted August 29, 2006 i use yamalube premix oil and i mix it 40-1 and there is oil comming out my pipe pretty heavily.. thats the lowest amount of oil yamalube recomends....is this normal? do you think i should use an even higher ratio like 50-1? let me hear your thoughts...... mods +4 mm stroke .80 over mild port cool head 22cc domes trinity single 35mm carb v-force reeds cpi pipes timing advanced 4 degrees k&n filter Your jetting could be rich. You can run lean oil/fuel mix and still have oil on the pipes and you can run 32:1 and have no oil if your air/fuel is lean. BTW, mine has oil on the ends of the CPI pipes all of the time. I jetted the main leaner and I seemed to lose a little HP, so I went back up. It still collected oil even w/the leaner jetting. I run Klots 32:1. I have a friend w/ the 35mm single set up and his smokes like a freight train, but he's never tried to fix it. Quote
spunmonkey Posted September 6, 2006 Report Posted September 6, 2006 I just noticed the same problem with mine. I got a 2 into 1 with a 38mm keihin carb. I finally got to ride normal after breaking in my motor. So i started with a 190 main 50 pilot and middle setting on the clip. Big flat spot on the mid range so i moved the clip. Cleaned up the flat spot. Still a little rich on the plugs. Ran a tank of gas through then put a 48 pilot in. Much peppier. I liked the way it ran. The left cyclinder sounded wierd though. So half way through the tank pulled the plugs the right was brown carbon fouled and the left had a white spot on it with carbon on the rest. I was used to looking at oil fouled plugs with the 2 38mm carbs when i trail ride. So now i am lean on the left. But i have noticed that it seems like it smokes more than normal. I now run 32:1 with mercury quicksilver oil. I get it free from work we buy it in 55 gallon drums. But i see that i have oil built up on the end of my pipes too. I still havent done a WOT test or rechecked the compression to make sure everything set right with the new rings. Gonna mess with it some more this weekend. Quote
b33rs Posted September 6, 2006 Report Posted September 6, 2006 I finally got my jetting pretty good and I still get a little oil spray when I'm running it hard with AmsOil 50:1. Just get your jetting good and try a new oil you might have better luck. :thumb: Quote
