FireHead Posted August 26, 2006 Report Posted August 26, 2006 WHere is everyone attaching the ground straps from the wires? Pictures would of people's intalls on the coil and wires would also be sweet ass. Thanks in advance. :baseball_santa: Quote
jbooker82 Posted August 26, 2006 Report Posted August 26, 2006 I put mine on one of the head studs. Just make the hole a little bigger and then put another nut on top. Quote
FireHead Posted August 26, 2006 Author Report Posted August 26, 2006 Someone needs to hook a brotha up with some pics. I need some bracket ideas. :baseball_bat: Quote
jbooker82 Posted August 26, 2006 Report Posted August 26, 2006 For the coil i just got some aluminum angle iron. Just make a backet out of it. I used the old coil for the bolt pattern for mounting on the frame. Then I just bolted the new coil to the other side of the angle iron. Sorry my GF has my digital camera so i cant get you any pics. Quote
FireHead Posted August 27, 2006 Author Report Posted August 27, 2006 For the coil i just got some aluminum angle iron. Just make a backet out of it. I used the old coil for the bolt pattern for mounting on the frame. Then I just bolted the new coil to the other side of the angle iron. Sorry my GF has my digital camera so i cant get you any pics. None of this is really a porblem for me. I would just like to see other people's setups, as they may have come up with a mounting solution that is sexier than mine. :baseball_mitt: Quote
FireHead Posted August 28, 2006 Author Report Posted August 28, 2006 I finished installing it this weekend. I'd take a picture, but no one did that for me, so now I am sad and bitter. :baseball_bat: Quote
racer Posted August 29, 2006 Report Posted August 29, 2006 I finished installing it this weekend. I'd take a picture, but no one did that for me, so now I am sad and bitter. :baseball_bat: take a pic anways, now youve got me curious. Quote
FireHead Posted August 29, 2006 Author Report Posted August 29, 2006 (edited) Al right now I know why no one wanted to take a picture of their setup. It's hard as hell to get a good picture taken down in there. I blew out my sandal in the process. Edited August 29, 2006 by FireHead Quote
RNBRAD Posted August 29, 2006 Report Posted August 29, 2006 I ended up not using the wires. They are pretty trick but I had some spiro pro wires in red and I just had to use those. I used like a 1/2'' angle aluminum. Cut the holes to fit the frame and then holes for the coil itself. Looks totally factory! Quote
jbooker82 Posted August 29, 2006 Report Posted August 29, 2006 I like the water bottle relocated up to the front. That is pretty trick too Quote
FireHead Posted August 29, 2006 Author Report Posted August 29, 2006 I ended up not using the wires. They are pretty trick but I had some spiro pro wires in red and I just had to use those. I used like a 1/2'' angle aluminum. Cut the holes to fit the frame and then holes for the coil itself. Looks totally factory! My wires are a little bit of a cluster at this point, I will have to see if I can do something better with them. I think I am going to have to get Brad to come over and clean my bike. I mean I thought it was clean ang shiney in there until I took that picture last night and then Brad posted his up right after me. Quote
racer Posted August 30, 2006 Report Posted August 30, 2006 Brads bike has a magical force field that keep it from getting dirty. and you too can have one, its a meth habbit. after a few hot rails of some good ice he gets out a dirty t shirt and spits polishes the whole thing. i think. Quote
csrmel Posted August 30, 2006 Report Posted August 30, 2006 has anyone ever dyno tested this coil on a banshee to compare before and after? Quote
FireHead Posted August 30, 2006 Author Report Posted August 30, 2006 has anyone ever dyno tested this coil on a banshee to compare before and after? Yep, my stock coil was old and gay, my new coil is shiney and has color matching wires. That right there is worth 2hp. I can take it to work tomorrow and see if I can get the engine on the dyno, but I am not sure that I care that much. It's starts easier for sure though. :baseball_bat: Brads bike has a magical force field that keep it from getting dirty. and you too can have one, its a meth habbit. after a few hot rails of some good ice he gets out a dirty t shirt and spits polishes the whole thing. i think. Hmmmmmmm. I see where I have gone wrong in my life, I transitioned from Red Bull to riding the white pony, as apposed to developing a meth habbit. Dammit, why do I always have to screw up! :baseball_innocent: Quote
csrmel Posted August 30, 2006 Report Posted August 30, 2006 Yep, my stock coil was old and gay, my new coil is shiney and has color matching wires. That right there is worth 2hp. I can take it to work tomorrow and see if I can get the engine on the dyno, but I am not sure that I care that much. It's starts easier for sure though. :baseball_bat: what i am wondering is if youre old and gay stock coil could of been replaced with a new stock coil and gave the same effect. i guess well never know. Quote
