Bansheeman1121 Posted August 24, 2006 Report Posted August 24, 2006 Ok just got done with a frsh top end on my 99, put on my new ported cylinders, v force 2s, and 30mm carbs . Starts 1st kick every time good compressoin, idles good a bit on the rich side, when you ride it it runs like shit, the motor runs comlpltly flat it has no kick to it at all, 1st you can feel it try to pull but everyother gear.... nothin at all. Its not a jetting issue i dont think i had 210 mains and tried up to 260 and it still runs horrible, also adjusted the needle no better, so basicly if you run it up the road theres no powerband to it, sometimes it will sounds like its gettin on the pipe but its not pullin, clutch is also good on the bike so anything that can get this thing runnin better let me no, thanx Quote
J-Madd Posted August 24, 2006 Report Posted August 24, 2006 (edited) 260 mains on 30 mm carbs?? What kind of carbs are those? Your description sounds like it's lean to me, maybe on the needles; you may check your new reeds also. Broken reeds can probably cause similar symptoms. Edited August 24, 2006 by J-Madd Quote
