Oh I see thank you for answer I'll now understand when I c it in a post! b33r's question's good too!
(I've seen in other post that the hot rod crank is suposed to be welded but this weld worth shit right?)
Correct.
Ask any builder on here, they will tell you they re-weld hot rod cranks...or pretty much any crank that goes out.
I'd also invest in a good quality TZ or Maxload PTO side bearing as well.
Insurance is priceless...
