tonyown Posted August 23, 2006 Report Posted August 23, 2006 When you guys speak about welded crank does it mean a balanced crank to elimate vibration on high revolution? Quote
Bansh-eman Posted August 23, 2006 Report Posted August 23, 2006 (edited) no , thats trueing a crank to make sure it isnt out of balance... welding it is to make the crank stronger so it does not seperate. Edited August 23, 2006 by Bansh-eman Quote
tonyown Posted August 23, 2006 Author Report Posted August 23, 2006 Oh I see thank you for answer I'll now understand when I c it in a post! b33r's question's good too! (I've seen in other post that the hot rod crank is suposed to be welded but this weld worth shit right?) Quote
dajogejr Posted August 23, 2006 Report Posted August 23, 2006 hot rod crank is suposed to be welded but this weld worth shit right?) Correct. Ask any builder on here, they will tell you they re-weld hot rod cranks...or pretty much any crank that goes out. I'd also invest in a good quality TZ or Maxload PTO side bearing as well. Insurance is priceless... Quote
