Tim573 Posted August 2, 2006 Report Posted August 2, 2006 I rebuilt my 2000 banshee and it ran fine for about 3 weeks and one day i was riding it and it started backfiring and sputtering and would only go about 5 mph. I had a air leak in one of my boots so i replaced them and it still does it. Both plugs were oil fouled so i replaced them and the new ones even had oil on them. I was running 20:1 the whole time. Does anyone have any advice? Should i run a different gas mixture? I have t5's, vforce reeds, ported cylinders, dyna ignition, aftermarket carbs. I am running 93 octane. NEED HELP Quote
1.6i Posted August 2, 2006 Report Posted August 2, 2006 (edited) have you checked your compression? why 20:1? i run 32:1 never had a problem with a fouled plug.. Edited August 2, 2006 by 1.6i Quote
Bansh-eman Posted August 2, 2006 Report Posted August 2, 2006 yea 20:1 is really rich in oil you should be at 28:1 - 32:1 Quote
Samdogmx Posted August 2, 2006 Report Posted August 2, 2006 yeah I'd try running 32.1 & get some new plugs Quote
TeamBigginRacing Posted August 2, 2006 Report Posted August 2, 2006 32:1..^^^^^^what kind of oil mix r u running? Quote
csrmel Posted August 2, 2006 Report Posted August 2, 2006 nothing wrong with 20:1 if youre jetted properly. 20:1 and 25:1 is the factory spec, afterall guys. Quote
dajogejr Posted August 2, 2006 Report Posted August 2, 2006 I agree...too much oil. I think the manufacturer keeps it rich to be safe. Too rich for my taste... What is your jetting currently at with your mods, and what kind/size/type of carbs? Quote
MYquadsFaster Posted August 2, 2006 Report Posted August 2, 2006 i run about 40.1 yamalube in my banshee and my plugs still look oily........02. Quote
duneloon Posted August 2, 2006 Report Posted August 2, 2006 You may want to look at your harnes. make shure it hasn't been burnt throgh to wire. Did you mod. it while it was apart Quote
