TeamBigginRacing
Everything posted by TeamBigginRacing
  1. Thanks guys, I bought the jugs of here and was told it had light port job done by k&t...I'll get them checked out tho
  2. porting on jugs or case?
  3. no it comes with whatever size piston kit you want
  4. since the jugs i have now r 64.5 mild port job can i use this kit...you guys got better ideas plz shoot! looking to spend right around 7 or less for this up grade!
  5. Link for kit http://www.ebay.com/itm/BANSHEE-DRAG-MOTOR-4MILL-VITOS-STROKER-CRANK-WISECO-PISTON-TOP-END-KIT-ENGINE-/110822570013?pt=Motors_ATV_Parts_Accessories&vxp=mtr&hash=item19cd8a381d info 4MM BANSHEE STROKER REBUILD KIT INCLUDING 64MM -66MM PISTON KIT WITH GASKETS SPACER PLATE,CRANK SEALS AND CLUTCH COVER GASKET {YOUR CHOICE OF PISTONS},VITOS TRUED,WELDED,PINNED CRANK 110MM RODS, EVERYTHING YOU NEED TO PUT TOGETHER . 639.00 DIRECT BOLT TOGETHER NO CUTTING OR GRINDING
  6. I'm looking at this kit in ebay that comes with 4mill crank, trued and welded all seals for lower case, spacer plate ect for around 700.00! i blew stock rod bearing and just looking to spruce up a lil! i don't have unlimited funds so working with a budget and you guys could tell me if its going to better or not worth it!? i'm going to stick with my jugs i have for now and set i have in sig! any help or in put would be great!
  7. what do you guys think about a 4mill set up with stock jugs that i bought off hq with k&t port work, i found 4 mill crank trued and welded all seals piston kit and spacer for around 700.00! i dont have unlimited funds but looking to spruce up since i'm in there!?
  8. sorry guys com crashed and forgot i posted this! warren mi
  9. Thanks Pat sry sprinklerman i didn't have paypal had to call in a friend!
  10. riding the shee befor 2011 is over
  11. hey, i'm in need of lower end let me know what you got and price...looking for bolt on ready i have a motor to add parts just has a bad crank! i'm in mi no matter! ty ken
  12. Do you have to use the Hinson billet clutch cover with the Hinson clutch basket??
  13. the clutch basket have the gear attached? can you send me a pix and how much shipped 48091?
  14. silly fagget dicks are for chicks!!
  15. Get new carbs!!!!
  16. Just flush it out with gas... i've never had a problem with mine!! take the motor out fill move the crank flip over and repeat till happy
  17. If it has stock carbs..replace!!! Stocks are junk!!imo Sounds like compression time to do the upper half
