nitroburner13 Posted July 25, 2006 Report Posted July 25, 2006 put the keihns on my bike and i dont know how to turn up the idle on carbs without adjusting the cable adjusters on the caps. can anyone tell me where to adjust em? Quote
bansheeseat$$ Posted July 25, 2006 Report Posted July 25, 2006 I'm asuming that you put keihin pj carbs on it if so you turn the choke lever for the idle adjustment Quote
BrockMoto Posted July 26, 2006 Report Posted July 26, 2006 on mine you can adjust it with the screw on the upper right side of the carb... but mine are keihin flat slides Quote
nitroburner13 Posted July 26, 2006 Author Report Posted July 26, 2006 on mine you can adjust it with the screw on the upper right side of the carb... but mine are keihin flat slides im runnin 36 mm pj's. i tried to turn the choke and my bike didnt respond. guess i need to fatten it up a bit. Quote
