I just bought this bike and am rebuilding it form the ground up. When I first got it, it wouldn't idle and was fouling plugs left and right. I have the engine pulled apart now and figured I might as well go through the carb as well. What size jets should I be running for 5800 feet and about 90 degrees with little or no humidity? I don't know if mods matter with jetting, but here they are in case. Full Pro Circuit exhaust, Vito's racing crank, cylinders bored .020 over, K&N filter and Trinity stage IV 2 into 1 intake. Thanks for any help.
Kevin
I was going to say 180 to 185 depending on how it runs. May be a 187, but you'll have to try them and see. DEK needle will work fine at that elevation.
THANKS so much for the help guys. I will check it out and see what I am at now and try these suggestions. thanks again. :clap:
Kevin
I had the same question and bansheeseat$$ told me to call Tim at Cascade Innovations which I did yesterday, I'd recommend the same to you. This guy knows his stuff with 2 into 1's, he's probably your best bet since Trinity seemed like they didn't want to help me to much with mine. JMO
The crank is a stock stroke. I put a 188 main in today. I also changed the pilot, I just can't rememeber what I put in at the moment. LOL. Anyway, we will see how this works. If it doesn't I will call Tim at Cascade.
