Layfield11 Posted July 22, 2006 Report Posted July 22, 2006 My banshee is loading when it is idling, but once you clear it out and take off it is okay, is that normal? any help would be great. Quote
DirtyFitz Posted July 23, 2006 Report Posted July 23, 2006 Do you mean loading up as in revving to higher RPMS or what? Quote
2bzy2p Posted July 23, 2006 Report Posted July 23, 2006 (edited) check to see if your filter is clean,, if it is then id take your airscrews out at half turn incriments untill it cleans up Edited July 23, 2006 by 2bzy2p Quote
Layfield11 Posted July 23, 2006 Author Report Posted July 23, 2006 No i mean its loading up while sitting and idleing, and i dont haft to use the choke ever. But i have turned my air screws out its about 6 turns out. would have the snurkle off the air box cause this? I have a new filter on it also. Quote
RILS Posted July 23, 2006 Report Posted July 23, 2006 No i mean its loading up while sitting and idleing, and i dont haft to use the choke ever. But i have turned my air screws out its about 6 turns out. would have the snurkle off the air box cause this? I have a new filter on it also. You shouldnt turn your airscrews out more than 3 turns.If you have to go farther than that your pilot is too big. Quote
Dinner Posted July 24, 2006 Report Posted July 24, 2006 No i mean its loading up while sitting and idleing, and i dont haft to use the choke ever. But i have turned my air screws out its about 6 turns out. would have the snurkle off the air box cause this? I have a new filter on it also. And taking the snorkle off the airbox will cause the engine to get more air, causing it to run lean, or better if you are too rich all the way through Quote
dajogejr Posted July 24, 2006 Report Posted July 24, 2006 6 turns? Did you check to make sure they're still there? List all your mods...we'll go from there. Quote
Dinner Posted July 25, 2006 Report Posted July 25, 2006 6 turns? Did you check to make sure they're still there? List all your mods...we'll go from there. He probably counted half a turn as one turn :: Quote
dajogejr Posted July 25, 2006 Report Posted July 25, 2006 Yeah, I think it only takes 5 or 6 turns to remove 'em... Quote
