Rebel3190 Posted July 17, 2006 Report Posted July 17, 2006 What is that little piece that bolts to the back of the head and points down and you hook that big rubber hose on it i think goes to the radiator,and where can i buy 1? Quote
TeamBigginRacing Posted July 17, 2006 Report Posted July 17, 2006 What is that little piece that bolts to the back of the head and points down and you hook that big rubber hose on it i think goes to the radiator,and where can i buy 1? on coolhead or the stocky...i might have 1 Quote
Rebel3190 Posted July 17, 2006 Author Report Posted July 17, 2006 stock,milled but i dont think that matters Quote
2003LimitedBanshee Posted July 17, 2006 Report Posted July 17, 2006 stock,milled but i dont think that matters Yes it does, because all aftermarket heads I'm aware of run a milled billet block and hose barb for this piece. What you are looking at is the coolant line heading down to the water impeller, then to be pumped back up to the radiator. Notice the line coming from your radiator to the front of the head? The line on the back is your return line. Quote
TeamBigginRacing Posted July 17, 2006 Report Posted July 17, 2006 Yes it does, because all aftermarket heads I'm aware of run a milled billet block and hose barb for this piece. What you are looking at is the coolant line heading down to the water impeller, then to be pumped back up to the radiator. Notice the line coming from your radiator to the front of the head? The line on the back is your return line. if its 4 the stock head i'm about 99% sure i have 1 if so it's yours let u know 2morrow around 6pm my time! Quote
