i am posting my shee up for sale.it has been a great bike. i have owned it snce 2001.my friend bought it brand new in 97 as a leftover year. it is a 96.i have 95 plastic on it now.he put only 50 hours on the bike.i have put around 200 hours on it. here goes.
20 over top end
namura power pistons
head shaved 20 thous. has 130 psi compression
mild woods and trail port work done
stock carbs,tors removed idle kits installed 240 main jets
motofast 2-into 1 pipe stainless steel(the stronger kind)
kn filter with sealed plate in the airbox.stator cover always kept sealed and no water has ever touched the stator.
has ricky stator high output stator.stock flywheel and timing
2 voltage regulators installed to handle the high output stator.
boyeson power reeds,stock cages.
dirt digger clutch.new stock basket
pro-design water pump and in line cooler.
chassis parts=
stock frame not bent. never rolled
has durablue heavy duty axle
new yfz 450 front tires
mud machine rears 90 percent tread left
all brakes are newer. i always kept the slides lubed and moving free.i always flushed mt brake fluid once a year to keep the systems clean.stainless steel braided front brake lines.
full aluminum body skid plates including a- arms
new a-arm bushings. new steering bearing.billet tie rods
all shocks are stock and good.no leaks
new nylon swinger bushings
12 tooth front sprocket.
led taillight in the rear
flames painted on tank plastic and a mod quad flame grill
i am sure i am fogetting some stuff. it is on stock crank. this bike has been perfectly maintained and i cant explain how i kept up on maintenance. if something clicked or looked like it needed replaced,it got done. i never let anything go till it broke.if there was a question, i replaced it. all brakes are ebc fa84r gold pads.
this is one of the sickest trail banshees you will find.it is completely setup for trailriding and hillclimbing.it was always ridden on trails. i never raced it. this thing has gobs of low-end torque.this is not the fastest banshee you will find.it is purely setup for trail riding.
you see what it is and what is done.i can track this bike down to the dealer 5 miles from me.it has clean vin and engine numbers.i am taking reasonable offers over 3000 dollars.this bike must be picked up in ohio. i can meet anywhere around the akron, cleveland,canton areas to arrange pickup.this bike has always had maxima 927 oil and premium fule run and oil was changed every 10 hours of use.nothing is broken or stripped. i will consider a partial trade for anice 350x or 85-86 atc 250r.i have lost interest in the quads and i need money more than anything.but i will consider one of these trikes for a partial trade. plaes dont ask me to part it out.i wont. it is too good of a machine for parting out. it has never left me broke down.the cdi went out one time and i replaced it.please, only contact me if you are ready to buy this.thanks and here are some pics.oh by the way.the painted tank plastic is not in these pics.there is also a custom made 12 pack beer cooler mounted on the back for those long rides.if you need more pics p.m. me or give me your email and i can get them to you
