I picked up some stock banshee jugs that are sleeved but not sure what kind of sleeve the bore is 69.50mm. these also are ported and polished with boost ports not sure what stage but they look pretty wild. My question is what is the cc's on a 69.50mm bore and what will I have to change as far as carbs sizes, big bore domes and anything else I'm forgeting . Thanks for any info. :headbang:
You will need big bore domes. Sounds like the 404 big-bore kit from shinity or someone.
OK thanks big red were would be a good place to start as far as carb sizes i'm running stock 26,s bored to 28,s rite now my friend says the port work looks like a wild mx port.
I'd go with 33s or 35s either will do nicely for you.
