no lights
well first thing is first get yourself a test light check 2 see if theres power comming out of the bottom end if there is then check to see if theres power getting 2 your resistor (cant spell lol)
and if theres power there then check 2 see if there power at your light switch
if theres power then check 2 see if theres power at your light socket
check all your grounds then check your ground that runs from your motor( the black wire comming from your bottom end) to the frame
hope this helps :ninja:
Glenn
did the lights go out when you were riding or was the bike sitting then next time you went out they stopped working? more often then not I have seen the light\run switch go bad. if you have a friend with a banshee see if he will let you steal his and plug that $hit back in and then see if its fixed
