fast@$$rider Posted July 9, 2006 Report Posted July 9, 2006 i did a search on this already but i didn't find what i neede so my front headlights don't work or the taillight i can't figure out what is going on i checked all the plugs and they are all plugged in so im pretty much stuck any ideas? Quote
liquedfire Posted July 10, 2006 Report Posted July 10, 2006 well first thing is first get yourself a test light check 2 see if theres power comming out of the bottom end if there is then check to see if theres power getting 2 your resistor (cant spell lol) and if theres power there then check 2 see if there power at your light switch if theres power then check 2 see if theres power at your light socket if theres power there check all your grounds then check your ground that runs from your motor( the black wire comming from your bottom end) to the frame hope this helps :ninja: Glenn Quote
creamsickle Posted July 10, 2006 Report Posted July 10, 2006 did the lights go out when you were riding or was the bike sitting then next time you went out they stopped working? more often then not I have seen the light\run switch go bad. if you have a friend with a banshee see if he will let you steal his and plug that $hit back in and then see if its fixed Quote
fast@$$rider Posted July 11, 2006 Author Report Posted July 11, 2006 well i just got this banshee and the lights wern't working so i had no clue i will take it to my friends house tomorrow and he qwill help me check it out. Quote
