My Shee (2001), wont start, i tried the choke but it didnt work, When i kick it without throttle it doesnt make a sound but when i kick it with throttle it makes a plopping sound (its like the pistons move but something goes wrong). i havent tried to push start it yet. But what do you think it might be, (more than 1 answers please) I just dont know what to do :banghead::banghead::banghead: maybe you guys can help me (ehat are my options)
fill it to the top my 01 didnt like to run lower than 1/4 tank and it would run on 1 cyl but i fixed it by evening out the lines and check your plugs if it doesnt fire then thats a diff story lol
Yea, there's gas (is it possible that is you store your shee for say 2 to 3 weeks that the oil slowly sinks and your mixture wil be screwed?)
I will check the plugs tommorow, but what is the best way to check if they're not fouled?
Shake the bike standing on the pegs for 5 to 10 seconds. That will eliminate your mixing gas worries.
For less than 2 dollars a plug, buy two new ones.
Air filter clean..?
Last time out, few weeks ago, did it run fine when you put it away?
i'l try it all, thats why i want many suggestions, so i can try the most common things before is take serious actions.
Yes it ran pretty fine, but because i didnt have enough time it stayed stored for a lil wile. But is this normal (after some storage that it wont start)
Appreviate all the help...thnx
Edited by herc_007
Normally...after storing, it might take a few kicks...but it should start.
3 weeks isn't long enough for gas to go bad...a few months, sure.
Before you pull all your hair out, might not be a bad idea to drain all the gas and put fresh stuff in if the easy things don't work...
