I get around 12.5 volts at idle with the lights on and around 13.9 volts at an RPM just off of idle. I only run a small 1.2 AH battery and it works great, I have not had any troubles.
Now if I want to add more lights then I would need a bigger battery for sure.
Are you running a rs stator and flywheel (200w)?
