00shee00 Posted June 20, 2006 Report Posted June 20, 2006 Can anybody tell me where the best place to get trans bearings is? :shrug: Quote
BenBB Posted June 20, 2006 Report Posted June 20, 2006 I couldn't find the mainshaft small bearing and the countershaft small bearing, or any manufacturer numbers on 'em when I had mine apart so you might be stuck with Yamaha there (so far Power Parts Plus has had the best OEM prices I've found). But you can go to a bearing store to get the other two bearings, just make sure they are good quality German or Japanese and not from China or Taiwan: Mainshaft big bearing - Koyo 83427 Countershaft big bearing - NSK 6305N/6305a5 You might have better luck than I did having them matched up, but if it helps the metric dimensions on the other two are: Mainshaft small bearing - 21x30 Countershaft small bearing - 21x33 Quote
