im getting rid of the two stroke and buyin another 450. so i have for sale a 97 banshee the mods are as follows:
Motor:
drag ported cylinders
stock bore
new wiseco superlite pistons
welded, trued crank
new clutch(heavy duty)
carbon tech reeds
2 into 1 intake 35mm carb, open k&n
new bearings, seals
head shaved with dome mod
trinity polished stainless pipes (normal and S/A endcaps)
dynoed at 83.5hp with bill's pipes should be closer to 90 with the new ones
Chassis:
stock frame very clean,straight
new swingarm bearings and seals
polished dogbone linkage
Electronics:
remove key switch (kick n' go)
dyna ignition with custom timing curves
there is about 20hrs on the bike since rebuild
im selling with holeshot tires
paddles extra
im asking $5500
Edited by socal_450rider
i cant figure out how to post pics, ive tried a couple of time and each time it says my pics are too big, i even resized them and still cant post them, yes i have the dyno sheet
Send them to [email protected] and I can post them up for you. Send them to me full-size and I can re-size them for you.
