I've been on here before for jeting help but that was when I had an airbox and pro flow, now I have two 3in x 4in pod filters not K&N though, not sure of brand right now but the are blue in color.
What size jets should I start with now, I have a stock stroke, bored 40 over, head milled 20 thousandths, boost bottle, boyseen rad valves and reed cages, tors eliminated, stock 26mm carbs with pods only, got rid of complete air box?
Elevation is about 370 ft and temps are around 80 to 90 degrees.
Also I have an almost brand new Pro Design Pro Flow Filter adapter plate that mounts inside your stock airbox if anyone is interested in it, its the one that accepts the oval shaped pro flow filters and the oval K&N filters.
Thanks for your help
Also do I need to get some outerwears for my new filters?
What other mods do you have?pipes,porting?
