I just put in a 4 mil stroker and i took it for a ride with my gas mixed for break in and the plugs look perfect. If i go to the proper mix ratio after the break in is my jetting gunna have to be changed because there will be less oil in the fuel? Im having a blonde moment right now so help me out please?
Mixing more oil in your gas is old school...
Some people still live by it...most don't though...
Mix the oil correctly, and do a plug check. Less oil in the gas will actually richen you jetting a tad.
Unless you're going from 16:1 to 100:1....you probably won't notice MUCH difference.
Mix it, ride it, chop the plug.
thanks a lot for the help
