momo20 Posted May 27, 2006 Report Posted May 27, 2006 i have a 87 banshee...had it for a while..summer is here..want to go out at night..i have the ricky stator Xenon Bulbs..but when the bike is running my lights dont work...the bike runs great.i have a 97 wiring harness..ok the fun part..when you go to turn on the lights, notting.but if you hook up 2 amps(positive) to the light blue wire in the back by tail light.while i am doing this i take the negitive and hold it to a ground..and my lights turn on...both high and low beams are working...sorry if this is hard to follow...but anyone have a ideal ? Quote
Justintoxicated Posted May 27, 2006 Report Posted May 27, 2006 (edited) sounds like your lighting coil is out on your stator, or you might have a bad connection fromt eh stator to the wiring harness. You could get a DIMM pretty cheap it would help. Grab a new rickystator with the adjustable timing plate. Won't hurt. Edited May 27, 2006 by Justintoxicated Quote
momo20 Posted May 28, 2006 Author Report Posted May 28, 2006 i am gonna pop next pay check and get the 200 watt stator..along with a new cdi box..what are the advantages of the timing plate Quote
GleasmJA Posted May 28, 2006 Report Posted May 28, 2006 sounds like the same problem i had when i redid me shee..... i had two wires reversed in the round plug up under the radiator. It was the Black/white and black wires reversed. It ran fine... but my lights didn't work. If i removed the negative off the tail light, the off/run switch would not shut off my motor. Could be that if you have that problem. Hope that helps. Quote
momo20 Posted May 28, 2006 Author Report Posted May 28, 2006 sounds like the same problem i had when i redid me shee..... i had two wires reversed in the round plug up under the radiator. It was the Black/white and black wires reversed. It ran fine... but my lights didn't work. If i removed the negative off the tail light, the off/run switch would not shut off my motor. Could be that if you have that problem. Hope that helps. 521542[/snapback] thanks i will look at that tomaorow... Quote
8buck Posted May 28, 2006 Report Posted May 28, 2006 This might help ya out a little... http://www.dunereview.com/electricalupgrade-1.htm Quote
momo20 Posted May 29, 2006 Author Report Posted May 29, 2006 This might help ya out a little... http://www.dunereview.com/electricalupgrade-1.htm 521701[/snapback] i read through that last night...very informative site...i am gonna do that when i get my new 200 watte.... Quote
