I just assembled and installed a 421 Cheetah p.v. in my 04. I used a Ricky Stator 200w stator. I have barely ridden it, (still working out the bugs). Its running well but Harry at Trinity says the bike will not run correctly with it, anyone have any experience with this settup?
Also when I first let off the throttle it idles a little high, but then after 5 to 10 secconds it idles down fine, any thoughts?
521316[/snapback]
I've never heard of such on the stator.Your idle sounds like you need to richen your air screws a half turn or go up a size on your pilots.
First of all thanks for your opinion.
I do have the Dyna box already. I had Trinity reprogram. Is that what you mean by programming to my motor or is there more to it than that?
Also i have 35 PWK's with 55 pilots, wich to me seams a little fat already. I sprayed the carb boots and base gasket down and there didn't seem to be any leaks. Still think maybe lean?
How much advance did you run? I have my adjustible plate at 2 degrees, and my box on the number 2 seeting.
Tunning this motor is obviously new to me, so any advice wiil be appreciated.
