MinEsFasteR79 Posted May 18, 2006 Report Posted May 18, 2006 this is to anyone that has ever had the fmf power cores on their shee..I have a grab bar from dg and the mounting brackets are long enough on the silencers therefore the grab bar restricts it from reaching the holes to put the bolts in..any grab bars that will fit with the pipes?? Quote
batoutofshell Posted May 18, 2006 Report Posted May 18, 2006 some times you have to use the rear billet hangers, they are straight a opposed to the offset fronts. Quote
MinEsFasteR79 Posted May 22, 2006 Author Report Posted May 22, 2006 alright..thanks a lot..sorry it took so long to respond..new to BHQ. i'm lookin at a stock grab bar..will that work?? Quote
bigboybanshee Posted May 22, 2006 Report Posted May 22, 2006 alright..thanks a lot..sorry it took so long to respond..new to BHQ. i'm lookin at a stock grab bar..will that work?? 519258[/snapback] Stock will definitely work, but I'm almost wondering if there is something you can do to make what you have work out....what kind of grab bar is on there now? Do you have a pic to better describe the problem you're having? Quote
MinEsFasteR79 Posted May 22, 2006 Author Report Posted May 22, 2006 I bought my shee used..and it came with a dg exhaust and dg grab bar..it worked out..but now im upgrading..but I don't know all that much about some of the aftermarket parts that the guy before me installed..the closest thing that I found to the one on it..is the dg fat series..and I would post pictures..but my digital camera was dropped (accident) and now doesnt work..basically..the bar is dropped down instead of straight back..for whatever reason..and the silencers on the fmf's are taller..but the mounting bracket doesn't reach up enough..so the silencer hits the bottom of the bar..and the hole in the bracket doesn't reach up far enough..if that helps any.. Quote
batoutofshell Posted May 23, 2006 Report Posted May 23, 2006 sometimes you haev to bend to fit also! Quote
fastbanshee8 Posted May 23, 2006 Report Posted May 23, 2006 The FMF silencers come with a mounting kit, that moves them out from the grab bar. I used to have FMF's and they cleared my fat grab bar, with the FMF mounting brackets. You should have got 2 aluminum spacers, 2 rubber grommets, 2 rubber washers, and 2 steel washers, with the silencers, unless you bought them used. Quote
MinEsFasteR79 Posted May 23, 2006 Author Report Posted May 23, 2006 I bought them used..but could I buy the mounting stuff from fmf seperate??? Quote
MinEsFasteR79 Posted May 27, 2006 Author Report Posted May 27, 2006 I "made" them fit without the mounting kit. I just used a lot of washers..it should work fine..thanks for all the help.. Quote
[email protected] Posted May 27, 2006 Report Posted May 27, 2006 i cut peices of metal tube and made some spacers costed me 2bucks at depot . i did it for a friend Quote
