Hi guys,
I bought me a new wiseco 4mm Hotrod stroker crank and a set of 1.5 oversize wiseco pistons. My question is what size domes do you think I should use on the head, and what should the expected horsepower be on the current setup???
4mm Hotrod Stroker Crank
1.5 Oversize Wiseco Pistons
FMF Fatty PowercoreII pipes
Standard size carbs
Coolhead 19cc domes
Reed Valves
Prow Flow Airfilter with no lid
Ported as well
Will I be in the mid 50's hp and are the 19cc domes a good setup or should I go bigger?
Edited by cloeter
You need to have your domes cut, to accept the pistons, because the pistons will come up out of the cylinders 2mm, and hit the domes, if they aren't cut. 18cc or 19cc domes should be fine, once they are cut.
516761[/snapback]
Thanx, I need to check those first!!!
Depending on your porting you'll either need some new cyls or some new porting. If you just drop the crank in I'd say you'd get MAYBE 2 HP more than a stock stroke crank. If you get the porting to match the +4mm, then you should be able to get up into the high 50's at least.
