Typiall O'rings do not need to be replaced unless they are brole ,cracked or warped. Personally I replace them everytime I rebuildd which is every two years. If you change domes quite frequently and the rings are ok then I would not wory about it. If you plan on keeping the domes in for a while buiy new rings, They are only about $20
Chris
Edited by Yaxy
Not unless, they are torn or defective. You can reuse them several times, but after some time, they will get hard and crack. If they get hard, or crack, or tear, then you need to replace them.
Chris
516638[/snapback]
ive found them cheaper at magicracing.com. i think like $16 or $17 shipped :cheers:
i have had the bike for about a year and never had it appart but i have
18cc domes in it and every one says they are to small and go with bigger
ones fore pump gas
they say that is probably what is causing by bog when i hit the gas
ones fore pump gas
516642[/snapback]
depending on where u live, 20cc u can still run 91 oct. i run 100 oct AV Gas in mine with 18 domes and havent had any probs, exp. sat night. ran it low on gas and i think i leaned it out and burn a hole in the piston :shootself:
my brother has a set of 19cc domes he said he would give me
i thought i could try them and see if it makes any dif at all i know it
is just one size bigger but it mite help a little
and im at 2900 ft
