I just picked up a Tors removal kit for my girlfriends banshee. I has the idle screws but there is no tap and no instructions on where they go. Can anyone tell me what size tap I need to get and where to drill and tap the holes for the screws.
Thx
Bascially, you'll see a plugged boss on the outside of each of the carbs.
It's next to the vent hose outlet.
Word of caution, place a small piece of wood or other soft object into the carb so the drill going through doesn't nick the other side.
Also, completely dissasemble your carbs, inclucing all jets prior to drilling or tapping...the slightest metal shaving in a jet will cause endless headaches.
Lastly, use a TON of penetrating oil like WD40 or PB blaster when running the tap, repeatedly. Aluminimum like oil...
Remember, 3/4 turn in, 1/2 turn out. Patience...well worth it in the end...
Good luck!
:cheers:
