i have 35mm airstrykers and was wondering what my float level should be how do i measure it and what should it be. I am running out of fuel on the right side when i am am WOT i don't have a pingel valve so that might be it. I would like to know though.
Unless you're running alcohol...you probably don't need a pingel.
Pingels sure are nice, but overkill for your (our) motor....
As posted in your other thread, I think it's 16mm for the Kehin.
Call Jeff...he'll know for sure...
Is your fuel line kinked or bent? try to find a Y adapter instead of that T...I'd invest in clear hoses, too...make sure fuel delivery is your problem.
you know what you do.... (have your bike off.) take your pods off, look upside down into your carbs and pull your throttle. make sure the slides reach the top at the same time. if not then adjust the pull screw.
