Toomey Banshee Posted May 11, 2006 Report Share Posted May 11, 2006 A little help here. My sons 89 Toy 4X4s' gas gauge isnt working. I'm getting a little tired of running the gas can to him when he runs out of gas . Anybody put a new sending unit in one of these? Big job? Do I have to drop the gas tank? Any help would be appreciated. Thanx Quote Link to comment Share on other sites More sharing options...
mnduner Posted May 11, 2006 Report Share Posted May 11, 2006 you may be able to sneak it out if the truck has a body lift at all. otherwise unplug fuel lines and electrical droptank-straps will probably break usually only like 30$ or so blow off top of tank so no shit falls in tank-not sure if sender is bolt in or has a ring remove sender, replace and reassemble. first id try unpluggin the electrical it may be a wiring concern. on fords open is full tank and 0ohms is empty. unplug and turn on key look at guage,turn off key put jumper wire in connector turn on key see if guage moves. id say level 7 on dirtyness and labor and level 3 on complexity Quote Link to comment Share on other sites More sharing options...
Mullet Man Posted May 12, 2006 Report Share Posted May 12, 2006 my '88 yota 4x4 has the same problem with the gas guage...i just make sure i keep it full. every 5 days or so, i top it off Quote Link to comment Share on other sites More sharing options...
Toomey Banshee Posted May 12, 2006 Author Report Share Posted May 12, 2006 my '88 yota 4x4 has the same problem with the gas guage...i just make sure i keep it full. every 5 days or so, i top it off 515083[/snapback] Thats what I would do, but its my kids truck, and he's 17. Nuff said. Thanks for the help. Gonna rip into it next weekend. Quote Link to comment Share on other sites More sharing options...
bansheefreak Posted May 13, 2006 Report Share Posted May 13, 2006 might check but it might be easier to lift the bed off normall only few bolts that holds it on... in our shop we had a ranger same problem took bed off and fixed it.. just an idea other then lying on your back trying to manhandle a gas tank thats prolly on gas in it Quote Link to comment Share on other sites More sharing options...
mnduner Posted May 13, 2006 Report Share Posted May 13, 2006 easier if tank nearly empty of course then its less heavy... problem with removing bed is its heavy too. unless you havea swingarm hoist. and the bolts come out real hard sometimes specially on older stuff easier still if you just cut a hole in the bed. Quote Link to comment Share on other sites More sharing options...
Mullet Man Posted May 13, 2006 Report Share Posted May 13, 2006 the beds are small on these trucks (mine is 7ft x ~54" wide longbed), DLX v6 model more then likely his '89 has the even smaller bed (most common) 2 maybe 3 people should easily be able to lift the bed off the frame after 1st removing the tailgate. then you should be able to access the trap door on top of the fuel tank Quote Link to comment Share on other sites More sharing options...
