alright can anyone explain hotcams to me? what all esle do u need to install with them? valve springs and stuff like? do u need to adjust valves more often? do you lose lowend power or topend? they would be for a 2003 z400
there are two stages that they sell, stage one and two. if you get stage one you will not have to get new valves or valve springs, if you get stage two you ahve to get new valve springs and i recommend you get new valves with the new springs but not necessary. the stage one you wont notice to much loss on the low end but you will notice more on the mid and top end. with stage you you will get a little more mid and top end with a little more low end loss. As with any performance upgrade there will be a little more maintennce as the lobe lift and duraton is larger but its worth it. After the springs are broke in and adjusted properly there shouldn't be any problems go stge two in my opinion.
