mattb348 Posted April 26, 2006 Report Posted April 26, 2006 Hey guys. I just found out why putting an RD 400 crank in a banshee is such a great thing. It apears that all you have to do is get a different ignition system, along with new pistons, when you put the RD 400 crank in. The RD 400 engine is the same exact engine as the banshee, other than the fact that it is 50 cc's bigger, and has an older ignition system. This makes putting in an RD 400 crank ALOT cheaper than buying an aftermarket one. I already have an RD 400 crank; I bought one on ebay for like $35 ($60 after shipping). Now I just need the newer ignition system. Quote
rocketboy Posted April 26, 2006 Report Posted April 26, 2006 (edited) Hey guys. I just found out why putting an RD 400 crank in a banshee is such a great thing. It apears that all you have to do is get a different ignition system, along with new pistons, when you put the RD 400 crank in. The RD 400 engine is the same exact engine as the banshee, other than the fact that it is 50 cc's bigger, and has an older ignition system. This makes putting in an RD 400 crank ALOT cheaper than buying an aftermarket one. I already have an RD 400 crank; I bought one on ebay for like $35 ($60 after shipping). Now I just need the newer ignition system. 507929[/snapback] yo u have been misinformed , a rd400 is alot different i n the fact the engine is air cooled,igniton is different, the crank uses longer 115mm rods, it also is a huge +8 millimeter stroke compared to your banshee crank ,in other words its not gonan fit with out case trenching ,your port layout on your she jugs wil l not work eve n remotely close without major modification ,your pistons wont work either nor the head unless these things are all modifed . you wil l surely need way more than yo u thought Edited April 26, 2006 by rocketboy Quote
mattb348 Posted April 26, 2006 Author Report Posted April 26, 2006 yo u have been misinformed , a rd400 is alot different i n the fact the engine is air cooled,igniton is different, the crank uses longer 115mm rods, it also is a huge +8 millimeter stroke compared to your banshee crank ,in other words its not gonan fit with out case trenching ,your port layout on your she jugs wil l not work eve n remotely close without major modification ,your pistons wont work either nor the head unless these things are all modifed . you wil l surely need way more than yo u thought 507936[/snapback] I see. Thanks for the info. You seem to be very knowledgeable on this. Quote
rocketboy Posted April 26, 2006 Report Posted April 26, 2006 (edited) i didnt want to dishearten you ,just wanted to let you know theres alot of things that need done to make it work that yo u havent accounted for , but im sure its possible and where theres a will.... theres a way good luck on your project Edited April 26, 2006 by rocketboy Quote
FIRST BANSHEE Posted April 28, 2006 Report Posted April 28, 2006 the rd 400 is a fast bike,that engine rips. I put the engine in a 250r frame years ago, it was awesome. also had a yz 400 in the same frame, that's also a engine that rips. Quote
