mybanshees2fast4u Posted April 25, 2006 Report Posted April 25, 2006 I just got 99 shee running and the thing blew the top end. When i got the bike it had a crack in the side cover that ran from the kick starter around the top half of the case. It would spew out transmission oil so i obtained a used set of cases from a rz streetbike, (I hope they will work). So now that the tope end needs to be replaced it is time to do the whole thing. My question is save from pistons, all the crankcase seals and the top end gaskets, what else do i need to do while the cases are split. Also what could have possible carcked the side cover and top of the case, should i be looking for something gone wrong in the kickstarter assembly? Should i replace any bearings in the bottom end. Any cheap mods i should do while its apart? Any advice would be great. Quote
bansheerage Posted April 25, 2006 Report Posted April 25, 2006 well dont know much about the cracked case thing and oil pouring out you might want to post a pic or something. but if you do decide to break everything open you could send the shift assembly to jeff at F.A.S.T and he will mod it with the easy shifter or smooth shifter. i havent done it yet but i will. its like 25 bucks or something like that and you get it back in 2-3 days Quote
bansheerage Posted April 25, 2006 Report Posted April 25, 2006 Farm And Sand Toys 10243 278 th road Holton, Ks 66436 785-364-5325 jeffs info Quote
