mattb348 Posted April 24, 2006 Report Posted April 24, 2006 I know a guy that used to have a banshee that was pretty decked out. His best mod was when he took a crank from an old yamaha RD 400 (road bike), and threw it in his banshee. The thing could pull the front tires up in 6th gear after doing this. The only downfall was that he had to buy a $700 ignition system for it, since the stock flywheel wouldn't fit anymore, and the ignition system in the old RD400 was junk (it was points) My question is this: is there any aftermarket cranks that you can buy that would even compare to the long stroke of the RD 400 crank? And if so, can you use your stock ignition system with them? And do they make a monstrous difference power-wise, like with the RD 400 crank? Thanks guys. Quote
blueshee03 Posted April 24, 2006 Report Posted April 24, 2006 the rd400 crank is like an 8 mill stroker. Quote
mattb348 Posted April 24, 2006 Author Report Posted April 24, 2006 yep an a 8mill 507068[/snapback] What exactly does that mean? I don't know crap about cranks Quote
trex banshee Posted April 24, 2006 Report Posted April 24, 2006 That means that the stroke of the rd400 crank is 8mm longer than that of the stock banshee(54mm). This means that the piston will move 4mm lower and 4mm higher with the rd crank over the stock one. Quote
banshee_08 Posted April 24, 2006 Report Posted April 24, 2006 would you have the room in the stock shit to do that ? or would you have to get new shit Quote
racer Posted April 24, 2006 Report Posted April 24, 2006 you can run a 4mm spacer between the jugs and case, or have ur head specially machined. Quote
badassbanshee479 Posted April 24, 2006 Report Posted April 24, 2006 to do this mod write you would have to get your cases trenched (clearenced for the crank throw) and you would have to buy custom pistons along with having your stock head clearanced for the added stroke or you can buy stroker domes for an aftermarket head there are a buch of companys out there making a 7mill crank or a 10 mill crank that will use all of your stock ignition parts, and a 10 mill would be even faster than that 8 mill your buddy had Quote
waycott_259 Posted April 26, 2006 Report Posted April 26, 2006 does a longer crank reduce reliabilit any? Quote
